Carver Water tank leaking
hostapparel
I have a Carver 1984 3607 aft cabin, one of the water tanks has a leak, looking to replace or can they be repaired? Also where can i find a replacement?, internet not providing options.
rbh
Re: Carver Water tank leaking
cracked or rubbed through???
Fireman431
Depending on the design of the tank, I have seen these lightweight plactic bladders that are placed inside the tank like big water balloons.
Might be an option.
rbh
i believe rubbed thru, have you heard of PVC cement working?
You could try building up the rub through part with a two part epoxy,
"BUT I do not know if it would be safe for drinking water".
make some call's
