Re: Catwalk for boat lift
Do you guys think that alum is the only material I should consider? What about galv steel or something like that? I was also thinking about using a few 4X4s to build a base (for example, take 2 or 3 16' 4xs, connect them to together using lags (and lots of overlap) and then build on top of that (as suggested, with a 2X10 or something like that to get me a nice walking area).
Something like this:
XXXX____V_V_V_________
__________________XXXXXXXXXXXXXXX
XXXX_______________________________
_______V___V___V__XXXXXXXXXXXXXXX
With the "V"s roughly showing the location of a carriage bolt and nut driven through all 4 boards). And then, of course, a 2X10 that would overlap all of that. Be heavy as sin, which could rule it out, although, in the water, it would be pretty neutral, so I could just use that to help me position it. Maybe I could do the same thing using 2X4s (turned on their side so the 4" side is facing up/down).
I'm just having a lot of trouble wrapping my head around a 1,000-1,500 dollar aluminum plank. That seems even more dear than most "marine grade" items.
