muskiedaze
- Joined
- Mar 29, 2002
- 24
greetings. i'm new to this board and think its great the way you guys help each other out. I'm a fishing guide and run 2 boats. I have a 2 stroke 50 HP Merc tiller on a 16 ft V-hull for the lake and a 50/35 johnson jet on a tunnel hull for the river. granted, I put on a lot of hours, but my repair bills have been insane. These motors are like a nightmare that never ends. For example, one month out of warrenty the merc seizes up. after 12 trips to the dealer he finally figures out that someone at the factory forgot to bend a lock tab on a bolt on the reed valve and it backed off into the crank. Dead motor. Merc coughed up a new power head for me but it still cost 500 bux to install it, and six more trips back to the dealer to get it running. (he left a plastic plug in the block some where and it took a factory rep guy to figure it out)then the stator went south. then this, then that.<br />The Jet's older and has been even costlier. here's a partial list of the things that have broken on the Johnson: drive shaft, engine mounts, tilt piston, fuel and oil pumps, control box,etc. etc. OK, you get the idea. I'm done whinning.<br />Now the latest. #2 piston burned up on the johnson and I have decided to become a marine mechanic. I had the cylinders bored and I purchased about 600 bux worth of pistons, gaskets and bearings. My concern is that I can't see what went wrong. There was lots of bearing wear. the piston looked like it was burning for a long time. the plastic cage on the center bearing was pretty much gone. no air leaks that I could see. #1 cylinder wasn't carboned up at all. Any ideas on what to look for? Thanks, I'll let you know how it goes.<br /><br />John
