cav plate at full speed
parrotthead04
Where should the cav plate be at full speed? right at water line? just below? Mine is about 2 inches below the water line. Thanks
D
DJ
Guest
Re: cav plate at full speed
That may be too low.<br /><br />Most importantly, where is it in comparison to the bottom of the boat?
parrotthead04
it is level with the bottom of the hull but it is setback about 4 inches because of a pt35 power trim and tilt unit
D
DJ
Guest
I think you have room to raise it. That water passing over the top is drag.
LubeDude
Originally posted by DJ:<br /> I think you have room to raise it. That water passing over the top is drag.
Yep, about 2 full inches because of the setback.
