cavitation plate height?????
fishskull
Hi everyone, Im new to the site and need some help. I have a 1979 valco aluminum boat with a 20" transom and I am running a 1974 25hp evinrude long shaft outboard motor. At wide open throttle the boat hesitates then grabs and the engine revs high. I was told it could be cavitation so I measured from the bottom of my boat to the cav plate and it is 3 inches above the bottom of the boat ( I was told it should be even). my question is where should the cav plate be at? also how do I lower it? do I have to cut my transom down 3 inches?? any help would be appreciated.
thanks
JB
Re: cavitation plate height?????
Howdy, fishskull.
Welcome to iboats. :)
What is happening is prop ventilation, and it is happening because the anti-ventilation plate (often incorrectly called the "cavitation" plate) is too high.
If you do, indeed have a 20" transom and your engine is, indeed a "long" shaft (20") there is something wrong with the rigging. The AV plate should be even to 1" higher than the bottom.
I suspect that your outboard is a short shaft (15") and is rigged as low as it can go or is a long shaft (20") rigged too high.
You will not get rid of the prop ventilation without fixing the rigging or mismatch.
Good luck, let us know what you find. :)
fishskull
thanks for your response, I measured from where the motor mount rests on the transom to the anti-ventalation plate and it is 18". the model number is 25403m it said it was a long shaft motor. do I cut the transom down or is there a better way to fix this without buying a new motor. thanks
