chieftaing
- Joined
- May 24, 2015
- 21
Project boat; took it out after replacing deck with plywood but before fiberglassing the replacement decking - all was good.
After a layer of 4 oz CSM fiberglass and resin, plus two layers of gelcoat, took it out and got wicked cavitation especially while towing a tube with 1 adult and on the turns. Nothing else changed - same prop, pretty sure the (manual) trim setting was the same.
Is this new cavitation and poor performance when in the water due to the weight gain from the fiberglass, or something else?
I did not try adjusting trim setting because the second tubing run experienced the motor dropping in RPMs due to either overheating (no buzzer, though) or I'm pretty sure due to the bolt that grounds the terminal strip coming loose, causing a major ground fault that took out the stator - repair in progress.
Will (manual) trim settings solve my cavitation problem? When do I need to look at a prop change? I'm sorry, but I really have no idea what's on there now - just know it was doing fine first time I took it out.
Thanks for any thoughts or suggestions!
