crackerjack
- Joined
- Dec 3, 2004
- 58
I've got an 18' bowrider with merc 3.0 i/o alpha drive. Had a 19" aluminum prop when I got it. Ran pretty good, but I noticed that at wide open throttle, it would go beyond its 4800 rpm "redline" to almost 5k rpm. I decided it must need a 21" prop. Thought it would bring the revs down and maybe get a little more top speed.
Well, it brought the wot revs down to 4800 but didn't get me any more top speed. Engine seems happier with the 21" than the 19" when I'm cruising, usually around 3500-4200 rpm. But now I've noticed I'm getting cavitation burn on the prop! On the trailing edge back of each blade about an inch from the hub theres a spot the size of a penny where the powder coat is chipped away and the aluminum is pitted. What gives?
Both are aluminum Vortex, 19" didn't do that.. ???
