roastinears
- Joined
- Aug 26, 2004
- 36
Howdy,<br /><br />I have a 1982 chrysler 75 hp model 758h2d serial # 1302. motor cranks right and runs in hot or cold weather, but the colder the lake water the longer it takes for all 3 cylinders to run. It seems to start all three and within a minute or so two cylinders drop and runs only on one cylinder. I can motor out on the lake and after a while (depending on the water temp) a second cylinder starts firing and then a little quicker after that the 3 starts firing. Before each cylinder starts firirng that cylinder starts intermittent firing then it finally catches and never misses the rest of the day. This has been very consistent. If I stay with it, shell come around and run like a champ. No more trouble once all 3 get going. One note here, I have made a modification by pulling the plug just above the thermostat and running a line to the cowling. Poor mans pee hole. Plugs are not fouling or crudding up. Am I not letting it get warm enough? Is it a coil or cd issue? Next trip I am going to plug the pee hole I made to see if it makes any difference. If anything I think it will only shorten the time for all three to fire. Again, once its going, she runs perfect. Running hole to hole bass fishing or skiing.<br /><br />Thanks in advance for the help
