I have a 1990 40hp evin. mod.# E40TEESR ser.#G02508599. It has the CD2UL ignit. system. I am just not getting the performance I feel I should. It dosn't feel like it's turning up full RPM. I don't have a test tack. I've gone over this motor several times in the past year. Fuel system,cooling system,jet pump,ignit. I've checked the sync. I also disconected (don't use) the vro. My question concerns this S.L.O.W. feature (speed limiting overheat warning)mode. Is it possable that the ignit module is stuck in slow mode. The cooling system is fine, motor dose not overheat and never has. I don't have an OEM manual for this late a model so I am reling on an after market copy and it dosen't cover any test procedures reguarding this. I assume the ignit. module gets a signal from the heat sending unit and drops rpm? Compression tests good also.
