Re: CDI Ignition Question (Compatibility)
As I said before, I only seen that one engine, and I did not make the switch over. It has been posted here before, but I don't recall the mods. that had to be made. I can't find anything in the 69 OMC service manual that mentions triggering on make. In the theory of operation at the beginning of the ignition section. It say's , the breaker point circuit, opened by the distribution cam triggers the amplifier. The points don't trigger the ignition coil, the amplifier does. If you switch to battery ignition, you will have to install a condensor across the points, like any battery ignition system.
