CDI rectifier less than 1 year old but getting 16 volts, why?!
Odawg753
hey guys i have a 1990 johnson 150 35 amp. changed the rectifier last year and now this year ive noticed im getting 16 volts which is way too high. it was a CDI rectifier, could it really have gone bad that quick??
ondarvr
The rectifier doesn't control voltage, it only converts AC to DC, the voltage regulator limits the volts. I'm not sure if that motor has a separate regulator/rectifier or if they're combined in one unit, but it would be the regulator portion that's not working.
Odawg753
im pretty sure its all one in the same
Did you clean the conacts on the battery? A bad contact would cause the regulator to sense low voltage on the battery side.
Also, verify the voltage with a test meter (dash gauges are not accurate)
Odawg753
yes contacts are clean, tested with multi meter
gm280
Have you tried reading that same voltage with the meter set to AC mode? Could be one of the rectifier diodes is shorted? JMHO!
oldboat1
no expert on battery systems, but charging two banks simultaneously? (e.g., bat. switch on both) If so might see what the output is on just one bank (set on bat1,). Don't switch with the motor running, just to be safe.
jakedaawg
Many times a failure is directly related to an operator error. Or an installer error. For example not having the batteries cables tightened with a wrench. Or failure to completely troubleshoot an entire system. Or switching a battery switch while the motor is running.
