champion or ngk plugs
magnum28139
hi, my question is,, I have a 1993 60 hp evinrude that does'nt seem to like it's champion plug's.if i dont get the fuel/oil mixed just right or let it idle to long then it seem's to foul out these champion plugs,on inspection the plugs dont look to be [wet]just black from the mixture,and a new set of plugs always fixes it right up.my quetion is, are ngk's ok for a evinrude motor,they are the best thing going on most other 2 cycle engines,i've had other fishermen to say to make the change while others said that the ngk was to hot a firing plug, thanks for the help,,magnum1954
JB
Re: champion or ngk plugs
Hi, Tim.<br /><br />What Champion plug are you using? Why are you replacing them rather than cleaning and regapping (.040)? Waste of bux.<br /><br />OMC specified Champion plugs.
