llerrad
- Joined
- Jan 21, 2003
- 172
Searay 20ft bowrider, Alpha 1, will the original transom and gimbal ring parts work for change out to V8 305 from the original 4 cyl 140. Will exhaust Y pipe fit up. I understand the leg will need to be changed.
Second question: when using alignment tool what is it you are bringing in to alignment? the gimbal bearing or do you adjust the engine into alignment with the bearing.
