Re: Change Pitch or Stay the Same
Stratos,
I see you being fine... if you like the current performance, (i.e., hole-shot and top end where you feel good). You may not always run with the family in the boat, so the rpm will be higher without them. You are within motor range loaded and (probably) when near empty. No need to change a good thing, IMHO.
Going to a 23P would be too much when you run empty and, if not watched, could send you over rpm max. Do a test run by yourself with low gas and a near empty load... I'm thinking 5500 rpm will be reached. If it stays below 5400, you could do a 24P and see increased performance. Still, no reason to change a good thing.
Ennnnnjoyyyyyy!
