Re: Change rotation of engine?
I'll try to make this long story as short as possible. Bought boat at bargain price. Old motor had a cracked block. Previous owner purchased a used motor from chevy truck. He swapped the intake, flywheel, and the starter. Previous owner then lost interest in the boat. I decided before putting the engine in the boat I would spin it over and make sure the starter was good. Now to the point. When I spin over the Chevy 305 standing behind it, it turns to the left. Counterclockwise. I believe the normal rotation for this engine is clockwise rotation. If I turn the input shat on the Mercruiser drive, with the control in forward, it turns the prop in the counterclockwise direction.
In forward gear:
Normal chevy rotation is clockwise, standing at back of engine. Prop turns counterclockwise. (Looking at the prop from outside the boat facing it.)
Starter that came from old motor turns motor in counterclockwise rotation, which would make the prop turn in the correct direction, but motor is not set up to run this way.
I know this is confusing, but I wish someone would please help me make sense of this. If there is no problem I'd like to put the motor in and try out the drive this weekend, but if it is wrong i'd like to start tearing it down.
