so file the points, gap them, verify the dwell and set timing........ its a 5 minute job.
how-too in the stickies at top of the forum.
learning about the simplest ignition system in the world is less costly than replacing it.
if the boat sat for 3 years, in addition to servicing the points you also need to start at the tank and go thru every bit of the fuel system and clean it all. Tank, pickup, anti-siphon, fuel filters and carb.
being your boat has points, it should also have the bat-wing exhaust manifolds (aka engine-killers) which you will want to change asap (unless they have already been changed to the upgraded center exit manifolds and elbows.
