Getting ready for another season....sorta......Getting ready for a weeks vacation over in s west Fl coast...I might be selling my boat so I don't want to go overboard but I don't want to run it for a week before I change my engine and out drive oils...also change the water impeller. I have a friend that is a mechanic and over the past couple of years have done these same things with me as assistance and now I want to do it myself. I have the manual and have been reminding myself of the process. As I recall, when we changed the impeller, he pulled the whole out drive off and then separated the lower gear case to change out the water pump.....is that necessary? Can't you just remove the lower gear case with the out drive attached? I have the manual but it really does not specify and shows the removal of the water pump in a general section taking the whole out drive apart. If I do have to take the whole thing off, is there anything else I should do? It is a 2007 boat with very low hours, probably between 200 and 300 hours. Also, the exhaust bellows has come off of the drive unit side which I have wrestled with before....I got it back on but it came off again. If I have to pull off the outdrive, I would like to take another shot at getting it back on. Someone told me about some product, and it seems like it was a merc product but not exactly the intended use, to stick that darn think back on...I lost my previous account and can't re trace those threads. If I end up keeping the boat, what next? Bellows replacement? I may sell the boat and get a express crusier type...then I'll really wear you guys out!
Thanks
Thanks
