John3
- Joined
- Jun 17, 2010
- 136
I have a 1967, 165 Hp, Mercruised, straight 6 (250 cubic Inch) in a 23 Ft. Dorsett Cabin Cruiser, weighing about 5500 lbs (Empty weight 3600 lbs). bought it in 72 & use it a lot. I munched the original OD and replaced it with a used pre Alpha with different gearing. With the old OD it would get up & plane with a normal load & I could run it at about 3400 RPM & 3 or 4 inches of vacuum. I took it out the other day & with the new (used) OD and 2 adults, ? tank of gas, water & minimal equipment on board it maxed out at 2800 RPM was definitely Not on Plane & zero inches of Vacuum. The prop is a Mercruiser 48-79570-15, 15? pitch & I think 15 ? inch diameter.
I?d like to get the performance back to where it was and at this point I?d rather change props than gears.
Anyone have a good formula for calculating a different pitch prop?
John
John
