johnkom
- Joined
- Jul 26, 2004
- 181
1976 Sea Ray Mercruiser 233 with MC-1 outdrive: I had the classic stalling problems when shifting out of gear. Changed the shift cable, adjusted and tested. Runs perfect in the driveway. Put a load on it (meaning in the water) and it stalls shifting from forward to neutral. Reverse to neutral is OK, "most" of the time. All adjustments and settings per Mercruiser. Now what?? Do the lower unit gears ever get draggy on the prop shaft?
