Re: Changing a idler axle to a brake axle?
I thought about the new/different trailer thing. I even went and looked at a couple. Although the boat is only an 18' aluminum w/100hp outboard, the trailer was custom built for it, and everything I've seen as a replacement aren't built half as well. My current axle doesn't have the 4 hole flange, that would be too easy! I do have 14" tires. Also, everything used I have been able to find needs work. I know I'd end up repacking the bearings, but might end up replacing them, plus new tires, probably a brake job as well (all I've seen are drums), not to mention lights and wiring.
I've read to stay away from Tie Downs. I've also read that the Kodiaks use a standard GM pad, so replacing them would be easy. Is this right?
Here's what I've been leaning toward: a Titan swing away actuator for about $300, and a new 3500lb axle that comes with the Kodiak discs and calipers for about $375. This way, I should be able to re-use my springs and rims. Any suggestions as to suppliers to check prices with?
