Re: changing carb jet
Year and model please
You will need to pull the bowl off the carb or carbs to check the main jet size. It will be the little brass guy on the side of the post protruding downward into the bowl.
The jet will have a number stamped on it. These numbers tell you what size, the size correlates to an elevation. For example: Sea level .074, .072-2,500-5,000ft, .070-5,000-7,500ft, .068-7,500-10,000ft. These numbers are for an early 90's 85hp, and yours may be different depending on the motor.
