Re: Changing from a Bravo I to a Bravo III
Also how do I know which ratio to go with on the Bravo III and which pitch I should go with on the propeller set up? I have never experimented with the duo props at all..
Howdy,
Your 26ft boat is fairly heavy.
I have a 21ft boat that weighs around 4200 lbs.
I installed a 97 454 (stock & carbureted) engine with a 1.81:1 Bravo III drive.
With 26p Props, and with only 2 people and 1/2 fuel(44 gal tank), it will turn 4600 RPM and run about 57 MPH.
Your boat probably weighs considerably more. I am thinking that you would probably need a 2.00:1 drive or a 2.20:1 drive.
With a stock 454, and a 2.20:1 drive and 24P props it might go 45 MPH at WOT.
I am guestimating what it might do considering the length and approx weight of that boat.
Your best bet will be to talk to someone with a similar boat that has a Bravo III installed and ask them about performance before you go out and and get another lower.
I did a little searching around an immediately
found one with a 454 and a Bravo III on the back.
You could call them and simply ask them about the drive ratio, prop pitch and performance.
Don't they still make Formula Boats? Call a dealer that sells them and ask them how they were set up with the 454/Bravo III.
Once you get some info, you can find a set of props on ebay easily. 24p props seem to be the most plentiful.
I had a 340 (crank) HP OMC 460 King Cobra installed in the boat I got from my brother (who bought it new).......... It ran 60 mph at 5000 RPM (400 RPM over recommended) with a 19p (cupped to 20) 3 blade prop but it was a REAL DOG out of the hole!
With the (330 crank hp) 454 and Bravo III, It's slightly slower, but it just ROCKETS out of the hole better than it EVER did even when it was new!! (My brothers words!!)
Good luck,
Rick
