I am about to change my gimball bearing as I had a torn exhaust bellow, u joint bellow and frozen gimball. I put the boat on forward gear and took the drive out. I noticed that there was water sipping into the u joint as it is a bit rusty but water didnot gush out when I took the bellow out. The exhaust bellow was really in bad shape. Well the drive oil is clean with no apparent water and was not leaking out. But, when I ran the boat on the drive way I noticed two things the water was not completly sucked into the boat from the inlet, so I assumed the water pump is defective. Also the water was not coming out at all from the exhaust outlet through the prop. I took the propeller out, and what a suprise. The exhaust casing in the lower unit is completly clogged. I kept on pulling more and more stuff from inside it. My suprise was that what I was pulling was nothing but the engine heat insulation that goes around the engine cover...how it got into the drive is beyond my understanding...I mean the whole thing is clogged, and the only way to clean it is while I am changing the water pump I hope. Funny enough that prop had no problem rotatting. Also Do I need to grease the u joints before I put the drive back in place. While I was cleanning the clogged exhaust I rotate the prop shaft..at start it was rotating in one direction, but now it rotates in both directions...I am worried I got the drive out of gear..the lower unit and the upper are still intact not seperated yet...how can I make sure that the drive is in forward gear...
Please share your thoughts and experiences as it is always appreciated. Thanks
