Changing Impeller ?
rl29
I got a ? guys. After installing a new Impeller in a 1987 force 125 shoud a guy use locktight or something on fasteners that hold lower unit on leg? And if so what would the number of the locktight be. I thought it said something in the manual but can't find it now. Thanks!!!
jackson
Re: Changing Impeller ?
no dont use loctite if i was to use anything it would be grease a good marine grease
rl29
Ok I'll go without. Thanks again. :p
wilde1j
If you boat in freshwater ONLY, put the fasteners back dry. If saltwater, use a light coating of NON hardening Permatex or gasket cement if you ever want to get the bolts out again.
