Changing long shaft to short 25 hp evinrude
69 Alumacraft
I want to convert a1976 25 hp long shaft lower unit to fit my short shaft motor. Can I simply take off the water pump and pull the long shaft out and push the shorter one in or do I have to break down the lower end?
F_R
Re: Changing long shaft to short 25 hp evinrude
You can just pull the shaft out. But the shift rod is a different story. Disassembly is required to swap it out. OR, if you are very careful, you can use a chainsaw file to make a new notch EXACTLY 5" down from the original, then saw 5" off the rod.
EDIT: If it happens to be a short shaft lower that was converted to long, you are in luck. In that case, it should have a 5" extension on the shift rod. Just swap that part for your short one.
