If you Replace the Vent Screw,+ Keep Pumping.........<br /><br />Yes,........<br />You'll Pressurize it,..... Till You Unhook the Pump...............Originally posted by simple:<br /> Is it possible to overfill it?
Don, should I put the vent plug in as soon as the fluid starts coming out, or should I wait until it stops draining out of the hole and then put it in?Originally posted by Don S:<br />Fill it till it comes out the vent hole. Put the plug in and then put the fill plug in.
