Re: changing lower shift cables
I did "customize" a deep socket and 3" extension in order to ease the removal and instillation of the nut holding the outer part of the cable into the hull. As for the clamp on the cable end of the bellows there is a wire tie type available from Merc........................Don once posted the part number......................I'd try a search. ................or hope Don stops by with the info...............good luck.
