Re: CHANGING LOWER UNIT SEALS
Why thankyou Mr schematic..
<br /><br />I did my lower unit on a 62 40HP lark.. stripped it completely, did the seals and swapped the forward and reverse gears around as reverse electic clutch had more meat then forward, (otherwise identical).<br /><br />did it with no special tools and no manual.. but I don't think I would try that on a newer motor.<br /><br />but if you must try it Boatboy.. go slowly, carefully and if you have a digital camera, take lots of photos while you take it apart,, very handy when you are trying to work out where the thingymabob goes..
<br /><br />To be honest, I think I'd rather pull my powerhead down then my lower unit.. they suk to work on unless you are equiped..<br /><br />rgds<br /><br />Frank
