Changing Oil?
jrmiah
Does a 98 Johnson Ocean Runner 2-Stroke - 200hp lower unit need oil changing?
tashasdaddy
Re: Changing Oil?
welcome. yes, atleast every year, before the first freeze. this is to make sure there has been no water intrusion. if the is water in the lower unit it will freeze and expand, cracking the lower unit.
Tim Frank
Re: Changing Oil?
There is always some wear in a gearcase which produces tiny metal particles which over time can cause accelerated wear; changing the oil gets rid of these bits.
Changing the oil every year is much cheaper than changing the lower unit every four or five. :)
jonesg
Re: Changing Oil?
Make sure you use new seals on the drain plugs, they are notorious for leaking water into the oil if re-used. Only $1 a pop at dealers.
