ab59
Ensign
- Joined
- May 10, 2017
- 979
Hello all , I have an inline 6 Merc that I just swapped midsections out so that I could have power trim. It is a 1984 115 hp. Mercury inline 6 . The problem is that one of the bolt holes do not line up or is missing on the mid. that has the PT so I cant use it. I did not notice this until I had already changed them out . I made the mistake of thinking that they would be the same since the serial numbers are within the same year. Now I need to swap out the PT assembly and transom bracket back to the Mid. to achieve my goal. What would be the simplest way to change out the Brackets and PT ? can I just take the yoke loose and slide the entire bracket assembly out to change it ? Thanks-----
Here is a quick video--
