changing prop from a yamaha to a johnson
epps408
Hi everyone. I'm trying to replace my old ss prop with a newer mercury tempest plus. The tempest came off of a yamaha and I'm trying to put it on my johnson. The problem is the hub sleeve wont go far enough down the shaft to tighten the prop. Any advice?
steelespike
Re: changing prop from a yamaha to a johnson
Would help to know the year and hp of each motor.
epps408
The yamaha is a 96' pro v 150hp and the johnson is a 85' v4 140hp.
steelespike
With some limited research I couldn't make the numbers match.
Perhaps I missed something.
epps408
I did a little research. Would it be that I need a hub kit for a johnson?
jestor68
Could it be that the V-6 has a larger gear case than the V-4?
Perhaps you have a prop that fits a 4-3/4" gear case and you are trying to put it on a 4-1/4" gear case?
Dhadley
The 85 140 should have the 15 spline 4.75" gearcase. We'll assume it does since you say the prop will slide on but the hub depth is wrong. If it is a new style square bore prop that uses an interchangable hub system then just get an OMC / Evinrude / Johnson 15 spline hub kit.
epps408
How can I tell if it's square bore? In the kit I see that square sleeve, but on my prop its just a circular hole.
dan02gt
If so the square sleeve fits into the prop from the back side. It should slide almost completely in with very little effort. The hole may look somewhat circular but trust me it's more rounded square.
epps408
Yeah, that's it. So the old square sleeve should slide out the back? I'll give it a try.
dan02gt
Yeah you should be able to tap it out. I usually take the metal insert that goes into the plastic sleeve and turn it to where I can use the keys on it to catch on the sleeve and tap on it with a hammer. It will pop right out like this.
