roger3645
- Joined
- Aug 30, 2005
- 271
I have a 1989 Sprint 265, 16? bass boat, weight of 950 lbs, 6.5? beam. It?s powered by a 1989 Evinrude 88 SPL. ( I added factory power trim) It currently has a 13 X 19 pitch, Michigan Wheel, aluminum propeller.
AT WOT I am running 5300 RPM, with a constant top end of 44 mph (GPS). Every now and then it will hit 45 mph, for just a second. I am considering changing to a stainless steel prop as I am looking for a little more speed.
Will adding a SS prop make that much difference in performance?
If so, I have read that I should drop the pitch to a 17 pitch when using a SS prop. Is this correct?
I have found a used 12.5 x 17 pitch ballistic SS prop for sale locally for $200, would this make a good prop for my setup?
Thanks
Roger
Thanks
Roger
