changing prop size and diameter?
88wellcraft
Hey there. What would the pros and cons be of going from a 15 x 17 aluminum prop to a 14 x 21 stainless? 1988 omc 4.3 ltr with cobra outdrive.
Thanks
tmh
Re: changing prop size and diameter?
You'll need to give more info I'd say. That's a big change so some variables mat be tough to guess very accurately.
What are you trying to improve?
Current WOT RPM and speed with 17" pitch aluminum?
You'll significantly reduce your WOT rpm and also probably holeshot. Top speed.....depends where your performance is now.
88wellcraft
forgot that....18 ft open bow wellcraft.....WOT @ 4600 rpm tops out @ about 52 - 55 mph. Not really wanting to change but found a cheap one on craigslist and thought if it would be any benefit, why not.
A 21" prop will be Way Too Much........
88wellcraft
I was kinda thinkin that...just wasn't sure if the smaller diameter would offset the pitch a little. I'll stick with what I have. Thanks for the replies:D
tmh
88welcraft, why not a 17" SS? You'd get better everything than now probably. You'd still be in/near recommended WOT RPM. High 50's mph!!!
What engine/year and outdrive ratio?
88wellcraft
Would an SS make that much difference? 4-6 mph?
