Re: Changing remote to tiller steer and throttle
They made a tiller-handle version of that motor, so you can do the conversion. You can actually buy a new tiller handle assembly at ishopmarine.com or at your local dealer for about $150. It's part no. 0305409. However, there may be some other parts that must be replaced, as well. I'm just not familiar enough with that model to tell you.<br /><br />If you want to go used, watch eBay or check with an outboard wrecking yard like tcoutboard.com.<br /><br />Lots of tiller 40hp motors out there, so the used parts should be available, and the wrecking yard will know what you need. That's probably your best, and most economical, bet.
