Re: changing selenoids to relays
You got the PT485 motor with the WH476 harness. Disconnect the battery, remove the trim solenoids, check to see if red wire on relay harness will reach main solenoid ,if so remove and discard red wire from main solenoid(starting) feeding the trim solenoids,remove the blue & green wires from trim solenoids,install the new relays to coil plate using old mounting holes and smaller bolts/nuts,install blue & green engine wire to the 14guage blue & green female connectors(you will need two male bullet connectors,do not crimp but solder to engine wires), install the large red wire with ring terminal to main solenoid(where you removed old feeder wire) remove old trim and install new one, plug the large bullet connectors(blue &green) into trims large female connectors and your done.
