I have a 1960 Sea King 5hp deluxe. I'm planning to change the shift dog to fix a jerking feeling that happens occasionally when running at higher rpms. Can I get to the thing by removing the very bottome part of the gear case? (there is a bolted seam right along the prop shaft held on by four screws) My maunual gives instructions for removing the entire gear case which includes taking off the power head, exhaust tube etc. Is it generally a bad idea to turn the shift dog around (so that the revervse side is contacting the forward gear) instead of replacing it. Also are there some seals that I should replace regardless of condition as long as I'm in there.
