Changing Thermostat 160-->170: Draining entire system?
chriscor
Hello,
I am running a Merc. 4.3MPI from 2005 (0W384629) with a closed cooling system installed. I'd like to change the thermostat from 160 (which I assume is being installed according to smartcraft values showing up) to a 170 Degrees Fahrenheit one. The boat is not being used in salt water. Do I need to drain the fresh water system entirely prior to changing the thermostat? Or, is there a walk around?
Thx, Christian
Don S
Re: Changing Thermostat 160-->170: Draining entire system?
You only have to drain it down lower than the thermostat.
chriscor
Thank you, Don.
achris
More fish than mountain goat
Hi Christian,
Your engine falls into a particular range, and I'm wondering. Do you have an oil leak from the front of the engine, down below the front pulley?
Thanks,
Chris.....
chriscor
Hi Christian,
Thanks,
Chris.....
Hi Chris,
I have not experiencend such an issue, yet. Fortunately. :rolleyes:
Will keep a close eye on this. Do you have any details?
Christian
achris
Hi Chris,
Christian
A little light reading for you... :D :D
http://forums.iboats.com/mercruiser...-v6-cracking-timing-covers-update-373060.html
http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/oil-free-bilge-finally-548054.html
Chris.....
(Love the first line of your signature.... )
chriscor
Chris,
Glad you got this issue solved - thank you for sharing.
Christian
rrose002
What if the engine is a 4.3 2004 merc sea water cooled would I need to drain it, if so what area. Thank you:confused:
Please Create a new Thread for your question instead of at the bottom of someone else's
