changing timer base.....change timing?
qflex1115
i am working on a 99 johnson 130. i'm changing the timer base do i have to redo the timing?
Faztbullet
Re: changing timer base.....change timing?
Please do as casting differences can result in 2 -6 degrees off!!
qflex1115
thanks, but would you happen to know what the full timing advance would be for my motor? model # j130pleed
qflex1115
what if i'm getting the exact same kind of timer base (cdi electronics)?
