So when removing my carbs to clean them I noticed the timing belt was cracked in numerous places and ordered a new belt along with the carb parts. I got the flywheel off and the top of the distributor gear for the belt but I am unsure of the best way to get the belt off and then back on the main part of the motor. There is a curved plate on top of the timing belt that blocks my pulling it off, though it slides a bit and I can kind of start one side off, but it doesn't slide as much to the other side. Do I need to further disassemble the top of the drive shaft and is it tricky to do? From looking at my manual it seems like I might need a special tool.
The pen is pointing to the plate I am referring to which blocks the belt from being removed. The part I am wondering if I have to remove is above the plate.
