nonstopgo68
- Joined
- Jun 18, 2009
- 51
to use a non vro pump, the new pump mount to the bosses on the block, and you block off the pulse line under the carb.
here is one without the VRO, see the fuel pump mounted to the block.
this is from an earlier post ... but my question is this .. there is a pan head phillips head screw right in the center of the bosses for the pump. the pump came with a gasket which as far as i can tell isn't anything but a cushion so to speak. can i mount the pump to the bosses right on top of that screw???
