Chaparral Engine Compartment Insulation
Stephen Brewer
Can anyone tell me the name/contact info of the company that manufactures the insulation that Chaparral currently uses in its 267 bowrider boats? Thanks in advance for your help.
tpenfield
Welcome to iBoats. . .
You could contact Chaparral, but the material is probably a common insulation used in marine applications. iBoats sells it . . .
Is this for the engine compartment or elsewhere?
Stephen Brewer
Ted: thanks for your note. It to replace the disintegrating insulation in the engine compartment of a 2003 Chaparral 260SSI. Any inquiries to Chaparral are referred to the local Chaparral dealer. I have contacted two dealers in my area and neither one can get any answers from Chaparral, which is why I posted my inquiry on this forum. SB
jbcurt00
Probably drilling a dry hole, not likely to get the info & if you do, insulation used in manufacturing on your boat, won't be available retail.
One of the marine engine bay insulation companies is soundown.com
