chaparral villian III weight ?
cuzner
Re: chaparral villian III weight ?
Davette, check out nada used boat value's,Along with value it also lists the weight of the boat.<br /><br /> Jim
davette:<br /><br />I can tell you. I have the original 1990 Chaparral catalog because I have the Villain IV. The Villain 111 weight is 3200 LBS.
penguin
THANKS , for your help in this matter, I needed to know to see if i can tow this with a 2001 s-10 blazer 4x4 w/4.3 and 373 gears. thanks
cuzner
Hey davette,just in case you had'nt thought about it,the listed weight is dry weight,fuel up add 2 batteries and equiptment + trailer& you can easily add 1000lbs to the weight.You should be o.k.,but don't expect to be doing alot of passing......<br /><br /> Jim
