charger hooked up backwards
tcampbell011
Hi, so I was hooking up my 1amp charger/maintainer that I bought from walmart and I accidentally put the + on the negative battery terminal and the - on the pos terminal. I noticed after about 60seconds and switched it back.
Now the charger doesn't seem to work. Do you think this damaged the battery? or would it just fry the charger?
thanks!
dingbat
Re: charger hooked up backwards
No damage to the battery. Probably blew the fuse in the charger. Easy fix
tcampbell011
Yup thats exactly what happened. A new fuse fixed the problem. Thanks!
