Re: Charging 16+ Volts
I am not sure what your question is but if you mean that your dash gauge shows 16+ volts when the motor is running, then either the dash gauge is bad or your regulators are bad. Use another voltmeter to confirm the voltage level and if it also shows the voltage as too high, then you need to replace your regulator.
