I have a problem and I hope someone has the solution. I have a boat that has three 12 volt batteries. One battery is for the outboard motor and is of no concern here as it is on its own circuit. The other two batteries were for the 12 volt trolling motor (hooked up in parallel.) I have a promatic 30-3 charger that charged all three batteries at the same time. Everything worked just fine. Then, the 12 volt trolling motor went kaput and I upgraded to a 24 volt trolling motor and rewired the batteries to produce the required 24 volts. Now I cannot use the charger to charge the two trolling batteries at the same time and I don't want to invest in a 24 volt charging system. So, what I have in mind to do is to find a switch that I can run the positive cable from one battery to a lug on a switch, run the positive lead from the charger to a 2nd lug on the switch and then the third lug on the switch will go back to the battery. This way I don't have to remove the positive lead on the battery each time I want to charge it. Can you help me find that switch, or in the alternative, explain how I can charge all three batteries at the same time?? Thanks, Ferris
