charging a deep cycle and starting battery
josephsiracusa
i am using an automotive charger to charge batteries now on the off season. i am confused.....my battery state on the sticker they are deep cycle/starting battery, it can do both......my automotive charger has a switch to select from conventional battery (which i assume is reffered to staring battery) or deep cycle. now having specified the type of battery, (which i use as deep cycle) do i select conventional or deep cycle on my charger? any help would be great thanks....
bruceb58
Re: charging a deep cycle and starting battery
Probably doesn't matter at all. What model charger is it?
UncleWillie
+1 ^^^
Probably won't matter.
The deep Cycle setting likely has a lower peak voltage with a slower, lower current, charge rate.
You are not in a hurry to charge so the battery would appreciate the slower charge.
If it is not a smart charger. Don't leave it on for more than an hour or so per month.
And certainly not overnight.
bruceb58
Get a 3 stage smart charger to replace your dinosaur. Your batteries will last longer and pay for itself.
tazrig
As stated a smart charger is really the way to go today. With so many different types of batteries out there a smart charger feels it's way through the charge and only gives your battery what it needs.
Barnacle_Bill
On-board smart charger is the way to go. As soon as you get back from a trip you plug it in and forget it until time to go out again.
