beckoning
- Joined
- Dec 15, 2010
- 161
I have 2 batteries with a Perko switch between them. I can switch to #1 or #2 or ALL. I use #1 (starting battery) for starting, #2 for electronics while trolling and the big motor is off, and switch to ALL when running on large motor in order to charge both batteries from the Mercury's alternator. I have a small, automatic charger I keep attached while the boat is in the hoist. For the last few years, I have connect charger's positive and negative to the positive and negatives on one of the batteries, then switch Perko to ALL assuming both batteries will be receiving a charge. Am I correct, or should I connect differently? Does anyone have a different approach to connecting the charger's + and - connectors so both batteries will be charging at the same time?
