I have three batteries, 2 for 24v trolling motor, one 12v for starting. When charging, with an on-board charger, one of the batteries for the trolling motor does not indicate a full charge as indicated by the row of lights on the charger. But, when I remove the battery and put it on a stand-alone charger, it checks out ok. Also, with this particular battery, there was a lot of corrosion at the negative terminal (lots of green fuzz). I cleaned it up, using baking soda water and reinstalled to the onboard charger. Same result: Not a full charge on the same battery. The charger is about a year old. Should I be suspecting that as the problem, or is it really the battery? I have not checked the wiring under the deck (pontoon boat) as all connections were soldered. The batteries are a year old as well.
Any ideas?
Respectfully,
Gary Oxner / Pinellas Park, FL
Any ideas?
Respectfully,
