I have just purchased a boat with twin 94 150 mercs which have been fairly neglected most of their lives. One had a blown powerhead which has just been rebuilt. Both motors run well now but the charging system is f'd on both of them. <br /><br />The first one charges at idle and as the revs go up the charge increases. At running speed the voltmeter slowly increases from around 14.5 to 16 at the same rev and eventually pegs the meter above 16. Thought the meter might be bad so replaced it with new one and get the same result. This motor has a 40 amp charging system with two rectifier/regulators going to a single solenoid. What kind of test can i do to see what is the problem?<br /><br />Engine #2 does not send any charge to the battery. <br /><br />By the way I have isolated the batteries to be one for each motor as I was having a problem figuring out why both batteries were going down at the same time. When they were run through system with both hooked to both batteries the motors would charge batteries fine and after about 20 minutes of running both would stop charging. Have no electronics running when checking charging system. Any suggestions as to whats up?<br /><br />Thanks
