bleedblue94
- Joined
- Oct 11, 2010
- 272
So let me start this thread by saying I am not above admitting when I have a brain fart. That being said I had one. A couple years ago I decided I wanted to upgrade the charging system on my J175txctd 1983 175hp sea horse from the 10 amp system to the 35 amp system. I have added several electronics to my boat and did not feel the 10 amp system would be sufficient, nor did I think it was a big deal to upgrade considering the next year omc started introducing more of the 35 amp systems from what I could tell. Thanks to information gathered on this board I knew I needed to change the flywheel, stator, and regulator/rectifier assembly. I used the following numbers: 0582572 FLYWHEEL ASSY., 35 AMP 0582574 STATOR ASSY., 35 amp. 0582904 RECTIFIER & REGULATOR ASSY., 35 amp The motor went together fine, ran fine, and I was satisfied. Just recently I have developed a tach issue and have traced the problem to a failed regulator/rectifier assembly. Now here is where the brain fart enters... While searching the net for appropriate part numbers to use for my replacement unit i noticed the term "liquid cooled" being used to describe the 35 amp reg/rec units. Needless to say, shortly into my information gathering i realized that the 35 amp unit needed to be liquid cooled and not air cooled. I have had no issues with the motor, wiring, or the assembly until recently. No melting, and not damage, so I consider myself lucky. Now the question I have is in order to get my motor back in operational condition, is there an air cooled 35 amp reg/rec assembly i can't use whether it is from omc or aftermarket? If so can someone provide the part number? If not, what are my options to cool this assembly? Thanks in advance!
